不能右键添加多个附件到邮件中
选择多个文件,点击鼠标右键,选择发送到雷鸟邮箱。进行已
All Replies (6)
re: Set Master Password , but do not enter a password directly off the password dialog box , you can view the message.
Most people who use and help on this forum use English. I was able to use google translate, but it would be much appreciated if you could do the same.
Master Passwords are designed to protect the mail account passwords from prying eyes, they do not protect from viewing emails. all this is fully explained here:
You should use - set up 'User Accounts' on computer to protect against access to your desktop view, access to Profiles etc.
首先感谢Toad -hall的回复,可是我的问题与你的回答不是一致 我的问题是: 选择多个文件,点击鼠标右键,选择发送到“雷鸟邮箱的快捷方式”,这一动作不能实现把所选的文件全部附到邮件上。只是附上一个文件 目前我只有把新建邮件窗口缩小,然后拖拉文件增添附件到邮件上。 附上问题的截图,方便大家帮帮忙。
Strange, I can mark and attach multiple pictures from Explorer or from different viewers at the same time.
If this is Windows- or Thunderbird that doesn't work right is hard to say.
Try running Thunderbird in safe mode.
Sorry IT-WU - I posted a reply to another of your questions in the wrong question. My mistake.
Thanks for images they clearly explain the issue.
I agree with Gnospen, I can select several images and use drag and drop method to drop into the Attachment area of a new Write message.
- Are you using 'Mozilla Thunderbird' or 'Portable Thunderbird' ?
- What version of Thunderbird are you using?
Did you try Thunderbird Safe Mode? 'Help' > 'Restart with addons disabled'
Thank you for your reply, my Thunderbird version is 31.4.0 I can drag and drop the file to the annex area I was through the right mouse button to send to mail the documents attached to the message, this can avoid the tedious operation and then drag the first new mail. I hope Thunderbird can be improved.
